Helios Fenix
Technical requirements
Minimum configuration
Multi-user deployment (client - server)
CLIENT (minimum configuration)
SERVER (minimum configuration)
Electronic signatures
When electronic signatures from class SHA-2 are used, the minimum operation system version is Microsoft Windows XP SP3.
Systems not yet supported
Oracle Database 12.
Additional information
The application is capable of operation in the terminal environment of Microsoft Terminal Services, or products such as Citrix. This transfers hardware and software demands to the side of the server.
Hotline and remote administration
Hotline Helios Fenix
- e-mail: hotline.fenix@assecosol.eu, when submitting a question via e-mail, you must specify the problem, organization, contact person and contact details.
- tel: +420 244 104 155, option 4 - when other lines are used, the first available number may not be searched and user calls may not go through. The phone hotline is available on business days from 8 am to 4 pm.
Regular consultations
Service Level Agreement (SLA)
Are you looking for the right solution for you?
More than 18 000 customers
Being active on the market for more than 35 years, we have implemented many specific solutions. Take a look at some of the most interesting ones.
It does not end with the module
Helios will make running a company easier
Small company
Company startup or the stability of a smaller business under your full control. We will show you how.
Medium company
Tame the processes of a growing company and support business growth. A perfect task for Inuvio.
Large company
A system that meets and adapts to the most demanding company requirements. That is Helios Nephrite.
