Helios Inuvio
Does its job. So you can do yours
An innovative business solution
The right information at the right time.
Use management data directly in your Inuvio and get the necessary reports and analyses quickly.
Our clients
Manage your business smartly. Use Helios Inuvio.
iNuvio is used by more than 4,500 companies in the Czech Republic and Slovakia.
Frequently asked questions
Give them to us! Each of your requests allows us to boldly move the system forward so do not be afraid to ask for something special, even when you already know that your business requires a very specific approach. We are accustomed to conducting communications with our customers from the beginning of our cooperation, all the way to the final handover of the system. And not only that. Once Inuvio is fully implemented in your company, we always stay in touch and help you with any problems.
We would like to give you the exact amount so you know in advance how much you have to spend but, our solution is so individual that we are simply not able to give you the exact calculation. Without a prior analysis of your needs and company processes, it would be difficult to estimate the amount in advance.
However, the benefit for your business is so fundamental that you will see a return on your investment already during the first year after implementation of the system.
It is in the order of months. We emphasize that a perfect understanding of all your company's internal processes is essential for covering all your company's needs.
Ideally, leave us your contact information and we will get back to you quickly. You may also take a look at our case studies and find out what we did for other companies and how we solved their system problems using Inuvio. You will learn that Helios Inuvio is a great choice for small, medium and, in some cases, also for large companies.
Of course. We have prepared a test environment with various data for you. We can provide internal testing and you can learn about the possibilities offered by the Helios Inuvio system. If you are interested in a demo please do not hesitate to contact us.
Member of the board
Is it not the right thing for you?
Solutions for any company
Small company
Company startup or the stability of a smaller business under your full control. We will show you how..
Large company
A system that meets and adapts to the most demanding company requirements.
Public sector
Focuses on digitization of processes and effective communication with citizens and organizations.
